Manufacturing Material Handling Packaging Components Product News Efficiency Optimization green
Cortec Adds New Sustainability Dimension to VpCI Barrier Paper for Metals Protection
Cortec Corporation is a long-time proponent of corrosion solutions that reduce environmental impact. One of those eco-conscious methods of metals protection is EcoShield VpCI-144 Paper, a corrosion inhibiting paper with a recyclable barrier coating. Recently, Cortec has taken this technology to the next level of sustainability with EcoBio VpCI-144 Barrier Paper, a new version with the added benefit of a biodegradable, biobased barrier coating.
It is hard to get much better than EcoBio VpCI-144 Barrier Paper when it comes to sustainable sourcing. Starting with 100 percent recycled paper stock, Cortec adds its time-tested VpCI coating (biodegradable per ASTM D6400) to one side and a biobased (90-100 percent renewable organic carbons per ASTM D6866), biodegradable barrier coating to the other side. The paper does not contain any intentionally added plastics, PFAS, or fluorochemicals.
The result of this formula is corrosion inhibiting barrier paper that is perfect for protecting metals at risk for moisture exposure and corrosion. Users only need to wrap metal parts with the VpCI coated side facing the metal, fold the edges of the paper together, and tape the paper to hold it in place. Vapor phase Corrosion Inhibitors from the internal coating diffuse throughout the package, forming a very thin, effective molecular layer of corrosion protection that does not alter the appearance of the metal. On the outside, the biobased, biodegradable barrier coating resists the entry of corrosive moisture and helps the packaging maintain integrity. Good grease barrier properties also reduce the risk of grease from lightly oiled components leaching through the paper. EcoBio VpCI-144 Barrier Paper can be used for wrapping or interleaving in countless metal packaging applications including
coils, wire reels, plate, bar, raw and machined forgings and castings, stampings, springs, bearings, fasteners, tubes, pipes and more.
After use, clean, dry EcoBio VpCI-144 Barrier Paper can be recycled through normal channels without the extra challenges that arise when reprocessing plastic coated or waxed papers. In addition, Cortec’s use of a biodegradable, biobased barrier coating has opened new possibilities for even more sustainable end-of-life disposal options (depending on local regulations). Whatever the case, EcoBio VpCI-144 Barrier Paper tackles corrosion protection + moisture/grease resistance while reducing the risk of pollution.
cortecvci.com
