Controx-Neuhauser Saw Blades and Side Milling Cutters On Display at PMTS
Controx-Neuhauser is presenting a full line of standard saw blades and side chip clearance saws suitable for a wide range of precision cutting applications in PMTS Booth#1145. Available in U.S. and Imperial dimensions with diameters from 1 inch to 8 inches and metric dimensions from 20mm to 250mm, with fine, medium and coarse tooth pitch to suit application requirements. In addition to these standard saw blades and side milling cutters, Controx-Neuhauser also stocks replacement blades for Hydromat, George Fischer, Rohbi, Bimax, Presstal Eisele, different Screw-, Swiss-type- and other machines. Controx standard saw blades are manufactured from High Speed Steel (HSS), Cobalt Steel (HSSCo), or Solid Carbide and are available with or without PVD or CVD coating to enhance performance and service life. An in-house heat treatment facility ensures optimum quality saw blades and fast delivery. They are ideal for a wide range of applications, including gold and silver jewelry, fastener production, resistors, electronics, thin or thick-walled pipes and profiles, extrusions, abrasive, high-tensile materials and more.
