Cone Drive Launches Series LE
Cone Drive Gearing Solutions has recently launched the new Series LE planetary servo gearhead to add to its AccuDrive line of products. The Series LE ratings are comparable to the current Series E, however the LE features a new output design which is dimensionally interchangeable with most economical planetary gearheads. The Series LE offers an improved motor mount connection and reduced noise levels in addition to:
  • Honed planetary gearing
  • High torque capacity and torsional rigidity
  • 200 percent shockload capacity
  • Exact ratios
  • Backlash as low as 6 arc-minutes
  • Universal housing: Mounts in any position; Compact - space savings; Rugged construction
  • Factory filled with grease: No vents or breathers; Maintenance free; no lubricant service required
  • Fast and error-free motor assembly: Motor adapter plate provided to mate to your servo motor; Integrated, zero-backlash clamping coupling
