Cognex Vision Sensor Powered by In-Sight
Cognex Corporation recently introduced the In-Sight 2000 series, a product line that combines the power of its In-Sight vision systems with the simplicity and affordability of a vision sensor. Suitable for solving simple error-proofing applications, these vision sensors offer proven In-Sight vision tools, a simple setup, and a modular design with interchangeable lighting and optics.
“For over 15 years, manufacturers around the world have relied on In-Sight to improve product quality, increase throughput and reduce waste. Now they want a cost-effective way to expand the use of vision technology down to the simplest applications—using the same setup software they use to solve more challenging vision tasks,” says Joerg Kuechen, vice president and business manager for Vision Products. “The In-Sight 2000 series can easily be applied to simple vision applications right out of the box, while delivering the reliable performance expected from In-Sight vision systems.”
The In-Sight 2000 series includes an integrated, high-performance image formation system consisting of field interchangeable lenses and a patent-pending LED ring light that produces even, diffuse illumination across the entire image, eliminating the need for costly external lighting. Customers can easily swap out the lens and change the color of the integrated ring light as needed for their application.
Together with the In-Sight Explorer EasyBuilder interface, which provides a fast, step-by-step application setup, the In-Sight 2000 series allows even novice users to achieve extremely reliable inspection performance in nearly any production environment.
