Boston Gear and Bauer Gear Motor Introduce Series 2000 Line
Boston Gear and Bauer Gear Motor, two Altra Industrial Motion brands, have combined their gearing expertise to offer the new Series 2000 product line. "We asked OEMs, end users and distributors what mattered most when it came to gear motor design." said Mike Stegmann, product manager at Boston Gear. "Their responses helped guide us in the development of the new Series 2000 Gear Motor product line." Utilizing the Voice-of-the-Customer, Series 2000 right angle helical bevel gear drives and gear motors are designed with many unique performance and convenience features to meet requirements in a wide variety of applications including dairy and bakery mixers, spiral heating and cooling racks, meat forming and processing lines, produce drying bins, bottling lines, unit conveyors and palletizers.
The Boston Gear Series 2000 C-face gear drives feature unique mounting registers and keyless tapered bushings for fast and easy installation. Units require very low maintenance with unique rounded housing surfaces for easier cleaning, premium acrylic paint pigmented with 316 stainless steel flake for high corrosion and abrasion resistance, and integrated O-rings for high leak and ingress resistance. Other maintenance advantages include automatic entrapment of wear debris, large diameter oil fill/drain holes and synthetic lubrication. Design flexibility is enhanced with a large assortment of shaft options, a variety of optional hollow bore sizes and input styles.
With efficiency of 98 percentĀ per gear mesh, Series 2000 helical bevel reducers areĀ suitable for use in applications with continuous or high duty cycle operations, high-ratio reduction, and limited access installations where long life is a necessity.
Bauer Series 2000 integral gear motors are inverter rated for use with VFDs. Motors are CE, CSA and UR certified, meet or exceed EISA 2007 efficiency requirements with a Class 1, Div 2, Groups B/C/D/T3C rated enclosure. Units also feature high quality bearings for long life and specially designed fans and fan covers for quieter operation.
