Gear Drives Product News
Bosch Rexroth Offers MCR8T Radial Piston Motor
Bosch Rexroth is expanding its range of direct drives for compact tracked loaders (CTL) and other tracked vehicles with the new MCR-T radial piston motor in frame size 8. The MCR8T represents the latest development in direct drive CTL track motor technology and, by utilizing the next generation of rotary group design, delivers a step change in power density and durability. The new rotary group design offers up to 55% increase in maximum torque, enhanced durability and a 20% increase in flow capability compared with the existing and dimensionally similar frame size 6.
The new design complements the MCR-T family, which is currently offered in frame sizes 5, 6 and 10. The compact dimensions, which are identical to MCR6T in all but a 10% increase in overall length, means that the motor is ideally suited for installation in compact loader tracks.
Rexroth‘s MCR-T withstands high radial forces thanks to its optimized load distribution. Larger bearings that are flushed with case oil combined with the latest development in sealing technology ensures exceptional levels of durability in the harshest environments. An integrated flushing valve contributes to increased service life by supporting the cooling of the oil when used in closed hydraulic circuits. In addtion, the MRC-T's well proven long service life and optimised design ensures a lower total cost of ownership for whatever mobile working machines the motor is driving.
MCR-T radial piston motors are designed for continuous high rotational speeds, in the toughest track drive applications, so that compact tracked loaders can also cover longer distances. Via the control valve integrated in the motor, the operator can shift smoothly between travel speeds with the soft-shift mode operating in both directions of travel.
In high speed mode the motor runs with a standard reduced displacement of 66%, which is also configurable on request, reducing oil flow in the circuit and improving system efficiency. Additionally, the direct drive design of the MCR-T results in greater efficiency, longer service life and lower noise than typical gearbox-based solutions.
Rexroth’s MCR-T motors function with a differential pressure of up to 450 bar with the MCR8T version achieving an output torque of up to 9,000 Nm. The displacement of the MCR-T product currently ranges from 380 ccm to 1,340 ccm and comes complete with a multi disc spring applied pressure released parking and emergency brake.
