Electrification Mining Off-Highway Vehicles Drive Systems Drives Gear Drives Gearmotors Planetary Product News Energy Efficiency Optimization IIoT Agriculture Transportation
Bonfiglioli Offers Drive Technology for Construction and Mining Machinery
In earth moving, the electrification process targets excavators (mini and midi) for which a special kit has been developed, combining three different components: an electric swing drive of the 700TE Series, ultra-compact and high-performing, equipped with an electromagnetic brake and speed and temperature sensors; an electric track drive of the 700CE Series, easy to install and maintain due to the reduction of mechanical parts; and an electric motor for pump drive of the BPM Series, featuring permanent magnets with SAE connections and ideal for the electrification of mobile machines. The system is completed by inverters responsible for motor control. By adopting Bonfiglioli’s Next Gen Electrification Approach, the Battery Capacity can be reduced by 50% thanks to the improvement in energy efficiency and reduction of maintenance costs.
Focus on Bonfiglioli’s flagship solution for compact track loaders: machines ranging from 1.5 to 6 tons, for which it supplies the planetary track drive paired with high-power density electric motors, specifically designed for electric systems. The 5-6 ton compact track loader version also integrates the IoT functionality through the sensorization of the gearmotor, allowing the user to view all the main operational data of the machine and use it correctly. Bonfiglioli's electrified solution represents a cutting-edge product already available as standard on machines from leading manufacturers.
For road construction, reliable, high-performance gear solutions have been developed, which keep the fleet of pavers and tandem rollers running smoothly. For both, a totally electrified solution is proposed, i.e. all drives – track and loader for the paver, drum rotation for the tandem roller – and motors – in the latter, the one responsible for the vibration and steering functions – are electric. The same transformation has also involved cranes and aerial platforms. For the former, Bonfiglioli develops winch drives – 800 Series – marked by high modularity and flexibility, thanks to the possibility to add further standard stages, motor flanges and bevel gears of the 300 Series. For aerial platforms, scissor lifts and boom lifts, Bonfiglioli provides the travel drives of the 600WE series, boasting compact dimensions, low noise and high efficiency. An advanced powertrain solution which uses a two- or three-stage gearbox offering reduction ratios of up to 1:145 to satisfy the widest possible range of needs.
A dedicated solution for twin shaft mixers used in the road and building construction has been conceived. An evolution of Bonfiglioli’s, modular planetary drive of the 300 Series – a highly versatile gear, due to several options for mounting, gear layout, output shaft – it is a specific bevel gear set which allows to have both e-motor bell housing and synchro drive shaft. Easy to fit and almost maintenance-free, it optimizes the machine structure, by avoiding the presence of pulley and increases the efficiency with a positive impact on the Total Cost of Ownership. The set guarantees the easiest layout configuration for asphalt and concrete applications by virtue of its simplified assembly and maintenance procedures.
For electrified mining equipment, the protagonist is the gear unit of the 3/H Series, a product boasting resistance, robustness, thermal capacity, high performance and torque density, thanks to the combination of the planetary and the helical bevel heavy duty gear units. In this case, the drive is integrated into an apron feeder, but also applicable to several applications, such as bucket wheels for stackers/reclaimers and horizontal roller crushers, as well as belt filters. For apron feeders, Bonfiglioli offers the entire system in an ultra-compact design, consisting of gearbox and motor that can be mounted directly on the machine shaft or installed with a base plate. All units can be supplied with IoT instruments for predictive maintenance function, able to measure real time working conditions, in order to support end users within their maintenance programs. The 3/H Series is designed to endure extreme environmental conditions, withstand temperatures ranging from -50 to +50 °C, high shock loads and extremely dusty environment.
Bonfiglioli is a leader in the development of hydraulic solutions, addressing the evolving demands of the industry. Today’s machinery must continuously enhance performance while becoming increasingly eco-friendly. This means that even non-electric machines must integrate smarter technologies to optimize efficiency. For earth moving machines, Bonfiglioli provides comprehensive systems incorporating all the hydraulic and mechanical functions: powerdrive, operating and travel speed, hydraulic and mechanical emergency braking and overload prevention. A groundbreaking technological innovation is represented by the 705XT track drive for high-performance compact track loaders, designed for high pressures and featuring fully variable displacement. A big plus which enables hydraulic gearboxes to continuously and adaptively adjust their operating parameters based on system requirements, therefore offering greater energy efficiency. Power can now be adapted to demand, better speed and torque control, in favour of optimized machine performance and reduced fuel consumption and emissions, making this track drive ideal for eco-friendly applications.
For the mining sector, Bonfiglioli positions itself as a full-line supplier, offering a wide, complete, well-adapted range of solutions, both for rotation and translation functions, which take on the harsh and dusty environment of mines. For large excavators, Bonfiglioli offers two sensorized travel & track drives of the F Series – F620 and FTU900 - targeting at mining excavators, respectively of 300 and 400 tons. Both ultra-compact and highly efficient, the FTU also simplifies maintenance, as its replacement does not require disassembling the entire track. Additionally, the drives can integrate IoT-based predictive maintenance functionality, which is extremely important for large machinery operating in challenging environments.
bonfiglioli.com
