Bonfiglioli and Schaeffler Collaborate on Wind Turbine Gear Drives
A compact Industry 4.0 solution package for wind turbine azimuth drives is the result of a long-term development partnership between Bonfiglioli and Schaeffler. Schaeffler Torque Sense and SmartCheck sensors record torque, speed, vibration and temperature information. These data are transmitted through a gateway, combined and processed using algorithms, developed by Bonfiglioli and based on the more than 60 years know-how in gear motors and dedicated specifically for the application. Subsequently, the data will be made available for the users on the Bonfiglioli Cloud platform. The Bonfiglioli Dashboard provides a clear overview of the collected information for the operator. Maintenance measures can be carried out in a load-oriented manner and the unplanned downtimes of the system can be minimized, and operating costs can even be more than halved.
On the Bonfiglioli dashboard, the operator can carry out a continuous control of the state of the geared motor based on the data situation; even an estimation of the remaining service life of the drive takes place. Abnormal behavior of the azimuth drive is reported as naturally as critical conditions. On this basis, the maintenance intervals can be optimized to the actual needs and necessary repairs can be made at favorable times. At the same time, the control of the drives can be optimized, whereby overloading can be avoided. Valuable result is the drastic reduction of unplanned downtime or vice versa, the significant increase in the profitability of a plant.
Concrete figures based on the example of a 2.3 megawatt wind turbine make this clear, as Gaetano Ciaravella, Bonfiglioli's Mechatronics & IoT Manager reported at a conference: Currently, the availability of a wind turbine is falling from 95% in the first year to 82% in the 20th year of life with a median of 88.5%. At the same time, the yields of a wind turbine are falling by about 7% per year due to lower kWh prices. The operating costs account for approximately 75% of the total initial investment in the 20 years of life. About 50% of the operating and maintenance costs are attributable to unplanned interventions. Specifically, this means that for a 2.3 megawatt wind generator in 20 years operating costs of approximately 1.6 million euros are estimated, of which up to 1.1 million euros are due to unscheduled repair and maintenance. With the help of the relatively small investment in the system from the cooperation between Bonfiglioli and Schaeffler, operating costs can be reduced by up to 60%.
In reality, there are certainly other advantages that are difficult to quantify due to the available data. They result from the possibility of adapting the electronic drives to environmental and operating conditions (e.g. temperatures, wind hours / year, etc.), which has a direct and positive effect on the productivity of the wind generator.
