Bodine Provides Variable Speed Control for Motors
The new type ABL-3906C low voltage brushless DC stock controls from Bodine Electric Company provide variable speed control for low voltage BLDC (ECM) gear motors and motors. The controls operate from a DC power supply or from a battery (12 VDC or 24 VDC, depending on the control model). They are suitable for portable or remote applications where connection to an AC line is not possible, such as mobile medical devices, solar powered water circulators, thermal solar power generators, chemical injection pumps at oil wells and automatic gate openers.
Motor speed can be controlled by an external potentiometer, the onboard speed trim potentiometer, or a 0-5 VDC analog input signal. A Smart Reverse circuit prevents plug reversing if the user accidentally or intentionally changes the direction signal without bringing the motor to a stop first. The controls have continuous output rating of up to 20 amps, and are capable of peak output current of up to 30 amps. Trim pots allow the user to adjust max speed, torque (current) limit, and acceleration time. The 24VDC models provide system-matched performance with stock Bodine 24V gearmotors and motors. Bodine also provides 12V gearmotors as OEM custom solutions.
