Bison's ServoNOW Designed for Single Axis Applications
Bison's integrated brushless ServoNOW servo system for single axis applications was designed to meet basic motion needs by limiting programmability and using simple positioning and speed control applications.  This state-of-the-art design reduces the amount of time and money spent on overall set-up and installation. All input and output functions of the ServoNOW are programmed into the set-up feature through a simplified indexing type command structure making it able to interface to nearly any logic input and output. Analog inputs can be selected and set-up to control the position or velocity of the system. All set-up and installation can be accomplished with any standard PC with a built-in USB port. Free, downloadable host software called QuickLaunch is available with the package and loads on any Windows PC. The ServoNOW incorporates an inclusive closed loop brushless servo motor with built-in driver, controller, magnetic encoder and 110/230VAC universal power supply all in one complete, compact package. Four programmable digital inputs and outputs, analog I/O (0 to 10 VDC or 4 to 20 MA, 12 bit) and position resolution of 4096 counts per revolution is included.
