Binder Expands M12-A Connector Portfolio for Sensor and Actuator Applications
Binder USA, LP, has expanded its M12-A connector portfolio with two new rectangular flange connectors. Designed for today’s advanced automation technology, the connectors provide new options for sensor and actuator applications.
The M12-A connectors include a stranded-wire version with 20mm or 26 mm rectangular housing, and a solder version with 20 mm housing. (The stranded-wire 26 mm version uses the same drilling template as the M16, allowing users to switch to M12 without changing the existing housing.) For simple and reliable installation, binder used a two-part approach consisting of the housing and the contact holder, allowing the coding nose of the contact holder to be positioned in increments of 45°.
