Belt Tensioners and Chain Tensioners-Zetasassi
QTC's Econobelt line includes over 330 Zetasassi belt and chain tensioners which improve performance by keeping constant tension. These maintenance-free tensioners are designed to reduce noise, transmit torque more efficiently, decrease wear, plus increase the life of belts and chain.
Click here to download or request the Q460 catalog.
http://www.econobelt.com/Q460/Q460cat.htm
In November 2002, QTC added over 9,000 off-the-shelf timing belt pulleys, belts, belt and roller chain tensioners and other power transmission components to our offering. These products designed for use in prototypes or for production applications are featured in our companion catalog Q460.
The 368 page catalog features Econobelt brand timing belts and pulleys in 11 different profiles: MXL, XL, L, HTD3, HTD5, HTD8, T2.5, T5, T10, AT5 and AT10. The belts are made of fiberglass-reinforced neoprene and the pulleys are made of steel, aluminum and nylon.
To download or request your free Q460 catalog, click here.
http://www.qtcgears.com/RFQ/
In addition to the over 3,700 metric gears detailed, this 528-page catalog contains a comprehensive technical reference section entitled "Elements of Gear Technology". The topics covered include the principles of involute gearing, gear dimension calculations, the definition of backlash, plastic gear design, elements of gear accuracy, principles of surface contact, methods of lubrication and methods for noise reduction.
The product section includes detailed specifications of the complete offering of off-the-shelf Spur gears, Helical gears, Screw gears, Ratchets & Pawls, Gear couplings, Worms & Worm Wheels (Standard & Duplex), Ring gears (Internal & External), Involute splines (Internal & External) , Racks (Straight, Helical & Flexible), Miter gears (Straight & Spiral) and Bevel gears (Straight & Spiral). These 3,700+ products are offered in sizes from module 0.5 thru module 10, in materials that include alloy steel, carbon steel, stainless steel, cast iron, aluminum bronze, brass, cast bronze, nylon, and acetal.
