Balluff Launches Pressure Sensor Line
Balluff’s new pressure sensors combine the advantages of a display, measuring transducer and pressure switch into a single device. Features include: over 130 versions available, IP67 housing rotates 320 degrees, bright display with easy programming (no tool required) and extended temperature ranges of -40 to 125 degrees C. The IP67 protection is suitable for use in gaseous and liquid media and its high quality, ceramic thick film measuring technology ensures performance and reliability. A large, bright and easily visible four-digit display shows the current system pressure in bar, mbar, PSI or MPa, and features fast and simple sensor configuration using two buttons and an intuitive menu guidance. Adapting to different process terminations is easily accomplished using optional adapters in various sizes and styles.
