AutomationDirect Adds Sensors for Food/Beverage Industry
AutomationDirect's new line of food and beverage sensor products includes AC and DC proximity and photoelectric sensors and quick-disconnect sensor cables. Compliant with the IP69K standard, the sensors withstand washdown conditions up to 212 degrees F and are constructed of FDA certified materials.The PFM 12 mm and PFK 18 mm proximity series are sensors with shielded or unshielded stainless steel housings and M12 quick-disconnect plug with gold-plated pins. Providing complete overload protection, each series has 10 models available. The PFM series has a standard sensing distance of up to four millimeters and extended distance of up to eight millimeters. The PFK series has a standard sensing distance of up to eight millimeters and extended distance of up to 12 mm. Models are available in a choice of 10-30 VDC PNP or NPN transistor outputs and normally-open or complementary output configurations.
Magnetic proximity sensors are available in 12 mm and 18 mm diameters. The shielded 10-30 VDC sensors have a sensing range of up to 70 mm and a normally-open output. Two series of 18 mm food and beverage photoelectric sensors have also been added. The FF series photoelectric sensors are available in 30 models and four styles: diffuse, polarized reflective, through-beam and retro-reflective (for transparent objects). Sensing distances range from 100 mm to 20 meters. The FFRS series diffuse photoelectric sensors with background suppression are available with adjustable maximum reading distances 30 to 130 mm and 60 to 100 mm for shiny objects. Sensors are equipped with LED status indicators.
