Atlanta Drive Systems Introduces Economy Planetary Reducers
Atlanta Drive Systems, Inc. announces a new range of Economy Planetary Reducers, offering good performance with an economical price level. Design features include standard low backlash, high power density, smooth operation and mounting to most servo motors (IEC, NEMA). They are available in four sizes with reduction ratios from 5:1 to 70:1 and output torque capacities up to 188 lb.ft. The output can be provided with a solid shaft with our without a keyway, for mounting to rotary or indexing tables, pinion gears, pulleys or other drive elements without the need for a coupling. These units are also available with output pinions for use in rack & pinion drives. Typical applications for these reducers include rotary axis drives, material handling axis drives, packaging machines, conveyor systems and, labelling systems. Industries served include material handling, packaging, textile, automation, aerospace, machine tool and robotics. Typical delivery time for these systems is only 2 to 3 weeks - ideal for OEM's requiring just-in-time delivery schedules.
