The recent trend toward using segmented laminations as a means to increase slot fill and facilitate automated fabrication of electric machines comes with a penalty of increased core loss at the segment joints.
This case study presents how electronics and software can be applied to a mobile hydraulic application, as well as how electro-hydraulics have evolved over time.
The demand for stepping motors with high efficiency and low losses has been increasing, although the demand had been previously focused on high torque. Also, the selection of the most suitable grade of lamination for improvement in fastening of the laminated cores has reduced losses significantly at their peak, when compared to conventional stepping motors. Lowering the losses of the motor has enabled continuous operation that was previously impossible. An expansion of the stepping motor’s usage into applications where another motor has been used for continuous operation and other uses—due to the
heat generation problem—can now be pursued. In addition, these motors are very effective for energy saving. This paper explains the technology used for lowering the iron losses of the stepping motor.
The Royal Danish Theatre has occupied
the heart of Copenhagen for centuries
and recently upgraded to a new control system featuring Sprint Electric DC drives to extend the lives of the existing motors, keeping replacement costs down. The Swedish stage design and technology company Visual Act retained most of the original motors and mechanics while providing a much-needed facelift to the stage.
Presented is a high-phase, order-induction motor drive for use in a series hybrid architecture. This solution overcomes numerous compromises in current hybrid powertrain designs. Notably, it allows for a vehicle that is competitive in terms of performance and cost.
Rising energy costs and concerns about global warming are at the forefront of today’s news. Turn to local or national TV programming, browse the
internet or read the paper and one can
find numerous stories about the seemingly irreversible energy costs and the subsequent impact that these costs have on simply doing business. As a result, we as individuals are becoming increasingly aware of the cost of energy and we are being introduced to a variety of methods
and/or products that will minimize the
impact of these costs.
For many years bellows couplings have been near the top of the list of flexible coupling choices for high-performance motion systems. Their high
torsional stiffness, low moment of inertia and minimal restoring forces under misalignment make them a preferred choice for maintaining tight control over the load.
In this paper, Edward Hage, founder of specAmotor.com, an online motor calculation and selection tool, focuses on the overheating of electric motors. Presented here is a calculation
method with which the temperature and heat development of a direct current (DC) motor and a brushless motor can be
predicted accurately.
Can direct drive technology improve your bottom line? Manufacturers relying upon drive systems in their production process have long sought ways to improve gearbox efficiency. While a gearbox-driven system has been the mainstay for manufacturers, it has also been, among other things, the source of frequent breakdowns, expensive line stoppages and increasingly costly maintenance.
Part I of this article appeared in the
October 2008 issue. It provided an overview and general classifi cations of power transmission couplings, along with selection and performance criteria for rigid couplings and misalignment-compensating couplings. Part II continues the discussion with selection and performance criteria for torsionally flexible and combination-purpose couplings.
