Motion control systems engineers work chiefly in two well-defined areas: 1) new designs and 2) redesigns or retrofits. This article examines the best approach for each option.
elements on the machine tool.
The demand for stepping motors with high efficiency and low losses has been increasing right along with the existing focus on high torque. The selection of the most suitable grade and improvement in the fastening
of the laminated cores has reduced losses significantly at their peak when compared to conventional stepping
motors.
How to select a guide wheel with the properties best-suited for a given application to create a system that reduces design costs and engineering changes, and lowers warranty, assembly, installation and mounting costs.
At first glance, ball bearings are
relatively simple mechanisms. However,
an analysis of their internal geometries
reveals that they are quite complex. For
example, the ball to raceway conformity,
the radial play, and the number of balls all impact the ability of a ball
bearing to support loads under a variety
of conditions.
Given that many different hydraulic systems recommend the use of either frequency converters or cyclic control (soft starter technologies), the question must be asked - Which one of these solutions is the most cost-effective in reducing energy consumption and providing the most satisfactory payback time?
Maximizing packaging machine productivity and performance is imperative to success and is driving OEMs to adopt and invest in the latest technologies that can meet their customers’ challenges. At the forefront of these performance-driven technologies is an integrated control system—or programmable automation controller (PAC)—and latest-generation motion solutions.
