In order to make better purchasing
decisions about centrifuge applications,
one must understand the concept of
centrifuges and the drives that operate
this equipment.
This paper provides an overview of the more common position sensor options and references actual case studies to
illustrate the diverse solutions available and the reasons behind some of the decisions. Three cases are used to illustrate the needs of different applications leading to the choice of a particular type of position sensor. The cases reviewed include a gantry crane, wind turbine and aerial cable car.
motors with premium efficiency counterparts presents businesses with a significant opportunity to reduce operating costs. A comparison between premium and standard efficiency motors from 0.25 to 10 horsepower is conducted; comparisons of full-load efficiencies are shown, and estimated payback periods are calculated. Methods for calculating the yearly kilowatt-hour consumption and yearly cost savings of premium efficiency
motors for this horsepower range are also given. The cost advantages of premium efficiency motors are summarized, and relevant examples of real world cost savings are shown.
A recent trend has been a movement to more user-friendly products in the mechanical power transmission industry. A good example of such a product is a high-horsepower, right angle, shaft-mounted drive designed to
minimize installation efforts. Commonly referred to as an alignment-free type, it allows the drive package mounting to be quicker, more cost effective and require less expertise during installation. This facilitates the use of the drive in applications such as underground mining, where there is little room to maneuver parts. The most common application
for the alignment-free style drive is for powering bulk material handling belt conveyors.
If you’re replacing your belts more than once per year, it’s time to analyze your drive. From belt crimping damage to high belt installation tension to sprocket misalignment and adverse environmental conditions, this guide walks you through how to identify the reasons behind premature failure and makes recommendations on corrective and preventive measures.
In an industrial application, equipment
uptime is vital for on-time performance and profitability. The rotating members of industrial machines are subject to the highest degree of wear and are more susceptible to failure than non-moving parts. Bearing surfaces are the most critical and often the most expensive portion of the rotary assembly; it is
imperative to protect these components. The primary protector of these components is the industrial seal.
Nitinol 60 (60NiTi), an intermetallic nickel-titanium alloy containing 60 wt % nickel and 40 wt % titanium, is shown to be a promising material for oil-lubricated, rolling and sliding contact applications such as bearings
and gears.
In the history of machine tools, spindles have been very good relative
to other bearings and structures on
the machine. So quality professionals
have developed a cache of tools—-ball
bars, grid encoders displacement lasers, etc.—-to help them characterize and understand the geometry of the structural loop. But as machine tools have improved in their capability and precision, and the demands of part-geometry and
surface finish have become more critical, errors in spindles have become a larger percentage of the total error.
