In this study the mechanical shear degradation of lithium-thickened grease was evaluated using an in-house-developed aging rig and a commercial rheometer. It was found that this grease loses its original consistency during aging and shows a two-phase aging behavior. In the first phase, primarily reorientation and breakage of the thickener network take place, resulting in a progressive drop in the grease's rheological properties. After this, the aging is dominated by the breakage of smaller fiber fragments and the grease degrades at a much slower rate.
Conservation through lighting alterations using different bulbs, ballasts and light sources is well understood and easy to achieve. The use of improved efficiency three phase induction motors has not been as accepted. There are a number of reasons why conservation efforts with motors have not been as popular.
Part 1: There seems to be a lot of confusion about the voltage standards for motors and why they are structured the way they are. Part 2: The effect of low voltage on electric motors is pretty widely known and understood, but the effect of high voltage on motors is frequently misunderstood.
As the old adage goes, "There is more than one way to skin a cat." In the early stages of any project, system designers are faced with choices; whether they are designing a new application or retrofitting an old one,
they need to determine what is the most efficient, economical and practical way of completing the task at hand. Though
there are usually at least two viable means to accomplish the task, the first step is always to review and weigh the merits of each option.
A bearing service life prediction methodology and tutorial indexed to eight probable causes for bearing failure and removal are presented - including fatigue. Bearing life is probabilistic and not deterministic. Bearing manufacturers' catalogue (L10) bearing life is based on rolling-element fatigue failure, at which time 90% of a population of bearings can be reasonably expected to survive, and 10% to fail by fatigue. However, approximately 95% of all bearings are removed for cause before reaching their L10 life. A bearing failure can be defined as when the bearing is no longer fit for its intended purpose. For a single bearing, you can only predict the probability of a failure occurring at a designated time - but not the actual time to failure.
A good deal of confusion exists regarding
the factors that determine an industrial
electric bill. The following information
is presented to help sort out the various items on which billing is based, and to offer suggestions on measures to help control and reduce electric utility bills.
Standardized calculation methods such as ISO 6336 and DIN 3990 already exist to determine the load distributions on gears inside a planetary gearbox, but by their very universal nature, these methods offer varying results depending on the gearbox design. Double helical gears, in particular, can benefit from more specific, complex algorithms to reach a maximum level of efficiency. Double helical gears interact with the rest of the gearbox differently than helical or spur gears, and thus benefit from different analytical models outside the standardized methods. The present research project describes the algorithm to determine the load distribution of planetary gearboxes with double helical gears.
In the process of applying industrial drive products, we occasionally are misled into believing that we are applying horsepower. The real driving force is not horsepower - it is torque. This paper is developed to impart a deeper understanding of torque, its relationship to horsepower, and the types of loads we most frequently encounter.
