The load carrying capacity of gear transmissions depends strongly on design, material and operation conditions. Modern analysis methods, e.g. finite element analysis (FEA), consider the above parameters with more or less sufficient accuracy. Yet it remains an ongoing challenge to account for backlash and manufacturing errors, despite a definite need to do so.
Microgears for some types of medical technology need to be inexpensively mass produced. But at the same time, they need to be both precise and reliable, even though their design lifetime is relatively short. Here's how microgears were developed for blood glucose measuring devices, insulin pumps for diabetics and other very small devices.
A worm drive is a geared power transmission device in which a worm meshes with a worm gear to transmit power between two non-intersecting shafts that are oriented at a right angle. The worm drive has been an active and challenging topic of technological study since Leonardo da Vinci (1452-1519).
Sustainability is becoming one of the most important aspects within the power transmission business. Users demand low-maintenance drive systems with as little disruption as possible, and expect lifetimes of more than 10,000 hours. Approximately 40 percent of long-term gearbox leakages can be traced back to poor interaction between the radial shaft seal (RSS) and the lubricant. Thus, it becomes essential to analyze the tribological system as a whole, which includes the gear oil, seal grease (if required), elastomer material and design, and the shaft.
Free vibration and dynamic operation testing of hybrid gears at NASA Glenn Spur Gear Fatigue Test Facility; hybrid gears are compared to their steel counterparts.
