The proof of the reliability of a gear drive is now an additional requirement. In Europe, the acceptance authorities for wind turbines are requesting a system reliability proof from gearbox manufacturers. The AGMA committee reviewing the AGMA 6006 standard for wind turbines is considering adding a chapter about design for reliability. However, reliability considerations are not new; NASA, for example, was in the 1980s using reliability concepts for gear drives.
Mainshaft bearings inside wind turbines are subjected to extremely harsh operating conditions that result in failure patterns which include surface-initiated fatigue, abrasive wear and uneven internal load distribution. This webinar will introduce you to the latest engineering advancements in spherical roller bearing design, including solutions that allow potentially damaging thrust to be safely transferred through the bearing to the housing support. The resulting reduction in torque, friction and heat significantly improves the overall efficiency of the system, thereby enabling the wind turbine to generate more power – more reliably!
Marvels of engineering have always drawn crowds. But when we think of tourist destinations, we think of old, opulent buildings like the Vatican or Versailles, massive, elaborately designed fountains, or skyscrapers.
After getting positive feedback on changes made to the show last year, AWEA Wind Power is doubling down and taking their ongoing transformation even further.
