Air-Operated Transporters Manufacturer Celebrates 25 Years
Vibro Industries celebrates the 25th anniversary of its line of Air-Operated Transporter Conveying Systems. Since the product's introduction in 1984, it has been reengineered to function without lubrication and has been field tested under actual manufacturing conditions at New Standard Corporation in York, PA.
The transporter uses two pneumatic cylinders instead of springs to operate on air pressure to move a product tray using oscillating conveying. It consumes .09 CFM at 60 PSI, a low level of air consumption, and it operates without oil. The Vibro Air-Operated Transporter is used in applications to remove scrap from beneath machine tools, materials handling operations, pharmaceutical and other processing applications. The product line includes seven units of various capacities.
"Our 24-year success is based on the longevity of our transporters and the customer service that we provide," says Leroy Johnson, president of Vibro Industries. "Our transporters are found in leading manufacturing companies worldwide."
