Gear Drives Product News
ABM Offers Compact, Cost-Effective Motors and Drives
ABM Drives' motors and drives are tailor-made specifically for the application whether it requires compact design, low-noise operation or maximum operating safety. A flexible modular design system allows cost-effective low volume production runs. Custom motors and drives are available for a wide range of application types: forklifts, electric vehicles, lifting technology, biomass heating systems, textile machines, wind power control, warehouse logistics, high-speed doors, air compressors, construction equipment, packaging machinery and vehicle-inspection equipment. The high overall efficiency of ABM Drives' helical and parallel shaft gearboxes reduces power input and energy consumption.
All products are engineered in-house. Components that represent a core competence are reliably produced in-house on state-of-the-art machine systems. This guarantees that electric motors, gearboxes, brakes and electronics are perfectly coordinated. Vertical integration of ABM Drives' manufacturing includes tool-and-die engineering and aluminum die-casting to guarantee best implementation and integration of components to a compact drive unit. High-quality gearing guarantees quiet operation. Tight-fitting housing covers and flanges prevent distortions that can amplify noise. Aluminum housings absorb harmonics and other vibrations better than cast iron.
A large center distance between the motor centerline and the hollow drive shaft centerline gives the application designer more freedom/clearance to integrate the unit into the application. Many layouts are possible, from integration of the motor into the gearbox housing, U mounting of the motor, to customizing the output shaft. The end result is a true plug-and-play motor and drive-unit solution designed to save time and money.
