AAC’s New Ring Type Natural Rubber Vibration and Shock Mounts Feature Lower Vertical Spring Rate
A new series of ring-type natural rubber vibration and shock mounts from Advanced Antivibration Components features a low natural frequency which will remain constant in a wide range of loads, providing improved vibration and electrical isolation. Typical applications for these units include use in rotating and reciprocating production machinery, compressors, pumps and blowers. The configuration of the V10Z47MRM ring-type mounts make them useful as production machinery mounts. They are available in two-ring, three-ring or combination mount varieties, with nine different mounting styles and ten different load ratings allowing for up to 90 available options. These ring-type shock mounts range in diameter and height from 2.36" to 9.06" (60-230 mm) and from 1.38-6.61" (35-168 mm), respectively. Ring-type units are designed for standard load ranges of 165-2645 lbs. (75-1200 kg). View Catalog Page for More Details and Quote Request
