AAC Wire Rope Isolators Designed for Heavy-Duty Applications
A new Series of 70 wire rope isolators from Advanced Antivibration Components (AAC) feature multiaxial shock and vibration protection, corrosion-resistance, maintenance-free operation. These mounts are featured at the AAC eStore where you can order online, request a quote, download CAD models, check stock plus view catalog and technical pages.
The cable itself is made from stainless steel and the mounting plates are made of aluminum. These cable mounts, identified as V10Z70-... Series are stocked in 1/16", 3/32", 1/8", 5/32", 3/16", 1/4", 3/8", 1/2", 5/8", and 7/8" diameter cable. They have a wide range of applications which include their use in: military applications, electronic racks, shipboard electronics & equipment, rotating equipment (pumps, generators, compressors), aerospace, on and off road transport.
AAC stocks a wide range of shock & vibration isolation products which include: stud & nut type mounts, base plate fastened mounts, wheels, leveling & foot mounts, suspension mounts, spring, steel mesh & cable mounts, bumpers, and channel mounts, bushings & grommets, pads & tapes, and couplings. These products are stocked in different materials including: rubber, neoprene, urethane, sorbothane, stainless steel mesh and springs. Many are suitable for use in extreme environmental conditions. Of special interest is a complete selection of Silicone Gel floor mounts, pads, sheets, plus paste-type thermal gel.
Detailed specifications are contained in Catalogs V100 and V115.
