AAC Offers Leveling Antivibration Mounts
A new series of leveling antivibration base mounts from Advanced Antivibration Components - AAC are designed to dampen shock and vibration for loads up to 4079 kgf (8993 lbf). Identified as the V12Z25M... Series, their housing and base are made of zinc plated steel and the isolator is made of a nitrile rubber compound to offer excellent pliability and elasticity. The maximum recommended load of the 4 isolators in the series ranges from 510 kgf to 4079 kgf (1124 lbf to 8993 lbf). The diameter of the unit base ranges from 80 mm to 200 mm (3.15" to 7.87"). They are featured at the AAC eStore where you can order online, request a quote, download CAD models, check stock plus view catalog and technical pages.
Typical applications include their use under controllers, large pumps, fans, motors, compressors, and other medium load equipment.
AAC stocks a wide range of antivibration and shock isolation products which include: stud & nut type mounts, base plate fastened mounts, wheels, leveling & foot mounts, suspension mounts, spring, steel mesh & cable mounts, bumpers, shock absorbers & channel mounts, bushings & grommets, pads & tapes, and couplings. These products are stocked in different materials including: rubber, neoprene, urethane, Sorbothane®, stainless steel mesh and springs. Many are suitable for use in extreme environmental conditions. Of special interest is a complete selection of Silicone Gel floor mounts, pads, sheets, plus paste-type thermal gel.
