AAC Gel Mounts Isolate Vibration
A new series of silicone gel mounts from Advanced Antivibration Components (AAC) are highly effective for isolating electronic equipment.  Applications include speaker systems, turntables, camera mounts, etc., they isolate vibration in low frequency applications with loads ranging from 0.11 lbf to 17.64 lbf per mount. The five mounts, identified as the V10Z61MA... and V10Z61MB.. Series have a collar ID of 3 mm to 4 mm (.12" to .16"). The bushings are made of silicone gel and the collar is brass. Operating temperature range is -40 degrees C to +200 degrees C (-40 degrees F to +392 degrees F). AAC provides products related to the elimination of vibration, energy absorption and protection of components and devices from shock and possible destruction. AAC stocks a wide range of shock & vibration isolation products which include: stud & nut type mounts, base plate fastened mounts, wheels, leveling & foot mounts, suspension mounts, spring, steel mesh & cable mounts, bumpers, channel mounts, bushings &   grommets, pads & tapes, and couplings. These products are stocked in different materials including: rubber, neoprene, urethane, Sorbothane, stainless steel mesh and springs.  Many are suitable for use in extreme environmental conditions. Of special interest is a complete selection of Silicone Gel stud mounts, pads, foam sheets, plus paste-type and sheet-type thermal gel.
