A New Series of AT10 Timing Belt Drives From Econobelt Are Now Available
A new Series of AT10 inch and metric timing belt drives from Econobelt are now available. The 162 pulleys, identified as the QPMAT10 in metric and QPEAT10 in inch Series, are made from 2024-T4 or 2024-T351 Aluminum Alloy or AISI 1045 Steel. All series offer double flange and flangeless types, with and without set screws for fastening to shafts. They are designed to fit inch shafts ranging from .3750" (9.525 mm) to .7500" (19.05 mm) and metric shafts from 8 mm (.3150") to 16 mm (.6299"). A series of 22 AT10 timing belts are also stocked ranging in pitch length from 500 mm (19.685") to 4030 mm (158.661"). These belts have teeth ranging from 50 to 403 and are stocked in belt widths of 16 mm (.630"), 25 mm (.984") and 32 mm (1.260"). The belts are made from nylon covered fiberglass reinforced neoprene with a loading capacity of 220 N/mm (1256 lbf/in.).
At the new Econobelt eStore you can get immediate quotes, download 3D models, and place online orders. Go to:
www.econobelt.com/Q460/RFQ/default.asp?Page=Pg_1-239_1.html Other power transmission solutions provided by Econobelt include over 9,000 off-the-shelf timing belt pulleys, belts, belt and roller chain tensioners and other components for prototypes and production applications.
Complete technical specifications are contained in catalog Q460, which is available to users of power transmission components free upon request from Quality Transmission Components, Division of Designatronics, Inc., 125 Railroad Avenue, Garden City Park, NY 11040-5016. Phone: 516-437-6700 Fax: 516-328-3343.
