Components Belts Motors Technical Articles
Improperly Testing Belt Tension Can Easily Damage Small Motors
Most of us want to just instinctively squeeze a belt between a pair of pulleys to test the belt tension. What is not as instinctive is just how much force such a procedure can put on the shaft -- often significantly past the manufacturer's rated limits for small motors. This can cause damage to both the shaft and the bearings.
This article appeared in the February 2019 issue.
