The range and flexibility of lubrication and sealing technologies continues to expand as companies look to scale down production times while increasing productivity. The industry is focused on environmental impact, automation and compact systems. Here’s just a few of the latest technologies in the industrial market:
Stainless steel ASK Couplings from Miki Pulley feature a unique “sliced” body structure making them an effective low-cost corrosion resistant solution that can accommodate many types of misalignments. The stainless-steel design makes them ideal for use in food and chemical applications.
Who doesn't love LEGO? While no parent enjoys stepping on them in the living room, I'd rather have my kids building a castle, a tower or a giant LEGO wind mill then watch their faces glued to their cell phones for hours on end.
