The 2023 EASA Convention, June 25-27, at the Gaylord National Resort & Convention Center in National Harbor, MD. EASA (https://easa.com/convention) supports companies involved in the service and sale of electric motors, pumps, drives, controls, gearboxes and other rotating machinery. Highlights include synchronous motors, machine reliability, leadership, sustainability, EASA's 90th birthday bash, motor maintenance, pump repair, supply chain issues and more.
ELIN Motoren and Voith launch the first electric motor with integrated safety coupling for the main drive of tunnel boring machines. Water-cooled asynchronous motors from ELIN Motoren contain either the Voith SafeSet to safeguard the entire drive train or the Voith SmartSet for continuous operation, even with frequent torque peaks. Torque limitation increases the productivity of the TBM, protects the machine components, and avoids costly downtimes.
The solar-powered butterfly is a 30-foot-long tiny house in the shape of a butterfly, which charges the electric vehicle it tows.
May 11, 2023
The SolarButterfly is focused on reaching millions of people, alerting them to the companies and individuals that are integral in transitioning societies away from fossil fuels toward clean energy technologies. Presently on a four-year journey around the world, the SolarButterfly plans to identify, record, and publicize at least a thousand climate protection pioneers and their solutions.
ABB recently announced it has completed its acquisition of the Siemens low voltage NEMA motor business. The transaction was originally announced August 11, 2022, and financial terms of the transaction were not disclosed. The business employs around 600 people and generated revenues of approximately $63 million in 2021.
Portescap announces the release of the 45ECF brushless DC flat slotted motor, the latest addition to join our flat motor portfolio. The 45ECF features a performance optimized design that utilizes an outer rotor configuration with an overall diameter of 43.2 mm and a body length of only 22.5 mm. The motor features hall sensors to easily control speed and torque and can be provided sensorless based on application requirements. Additionally, the motor can be used in combination with existing gearbox designs to provide high output torque at required operational speeds.
Hägglunds hydraulic drive systems are a familiar presence in the mining and mineral processing industries, as well as in related materials handling applications. Compact, gearless and utterly reliable, they offer significant advantages over their electromechanical counterparts. Those advantages continue to grow stronger, and the range of possibilities they create is set to expand.
It’s called the d2, a small, lightweight, nanoliter microplate dispenser—say that five times fast— used in lab automation to handle a variety of liquids. Created by UK Robotics, the liquid handler was launched in 2022 to shakeup the possibilities of moving liquids around the lab on a budget.
