In this study, a finite volume CFD simulation model of a single-stage injection-lubricated test gearbox was applied to investigate its oil flow and no-load power loss. The results provide physically plausible information on the oil supply and its distribution.
With the increasing mechanical power capacity of gearboxes, the thermal power limit tends to become the limiting factor. To achieve a balanced system, the gear unit needs extra cooling. Using a fan that is mounted to a fast rotating shaft is a common solution. For this solution an optimal design is investigated.
