Whether you design, build or maintain industrial equipment, it is likely you have encountered many types of bearing grease over the years. Lubrication plays a crucial role in virtually all operations, and certain key characteristics allow grease to perform its job better in demanding applications.
In the selection of lubricating greases for plastic worm gears, the user needs to know the influence of each grease constituent on the tribological performance in order to choose the appropriate lubricant. In this work, the effect of NLGI class, viscosity, base oil and thickener type are investigated separately regarding the efficiency and temperature close to the tribocontact. With the help of this contribution the user understands the effect of each parameter and learns about the potentially reachable efficiency and temperature ranges.
In this study, a finite volume CFD simulation model of a single-stage injection-lubricated test gearbox was applied to investigate its oil flow and no-load power loss. The results provide physically plausible information on the oil supply and its distribution.
For a maintenance crew, it is important to know which bearings need re-lubrication and make sure they are lubricating those bearings. The bearings can be lubricated manually or by automatic lubrication systems. This article
will review each method and discover its pros and cons.
