For a maintenance crew, it is important to know which bearings need re-lubrication and make sure they are lubricating those bearings. The bearings can be lubricated manually or by automatic lubrication systems. This article
will review each method and discover its pros and cons.
Heat generation in bearings is manifested by the power losses of the transmission. Because of the rise in temperature due to heat generation, the appearance of dilatation adversely affects the bearings' geometrical characteristics.
