This paper is intended to enlarge the application range of radial cylindrical roller bearings by means of a more precise determination of thrust load capacity and more cost-effective design.
Even when the critical components of industrial power transmission gear drive systems are properly designed, specified
and manufactured consistent with application requirements, performance
problems can develop over time and failure may follow.
elements on the machine tool.
We all dream of being our own boss, but living that dream is a rare reality. Not
so for employees at Isthmus Engineering
and Manufacturing, an entirely worker-owned cooperative, where each member has a vote in every aspect of the business.
When your $100 “Rolex” falls apart on your wrist, well, what did you expect? But when bogus bearings find their way into safety-sensitive applications, lives are at stake.
Robots are everywhere these days—
bots in the factory, bots in space, bots at the airport, bots in the movies and much, much more. But robots in the operating room?
