This three-part series on motor management best practices focuses on the importance of instituting a motor management plan as a necessity in effectively administering the electric motors in a facility. The goal of a motor management plan is to take advantage of opportunities for energy savings and increased productivity using energy efficient, reliable
motors such as NEMA Premium efficiency motors, herein referred to as “premium efficiency” motors.
When comparing bearing suppliers,
engineers are often left with few options
other than to compare dynamic
load ratings and corresponding life
calculations. Of course, we can look at
steel and manufacturing quality; but
if we are comparing sources of similar
quality, those items may not provide
a large contrast. It often surprises
people to learn that bearing capacities
are calculated values, not tested values.
Lately, however, a trend is emerging
for bearing suppliers to increase their
ratings for higher performance bearings
that have premium features such
as higher quality steel and specilaized
heat treatment. Bearing companies are
under intense competitive pressure to
make every feature add to the dynamic
capacity of their bearings because it is very well understood that an increase in capacity adds to the bottom line.
Beginning with a brief summary and update of the latest advances in the calculation methods for worm gears, the author then presents the detailed approach to worm gear geometry found in the revised ISO TR 10828. With that information, and by presenting examples, these new methods are explained, as are their possibilities for addressing the geometrical particularities of worm gears and their impact upon the behavior and load capacity of a gearset under working conditions based on ISO TR 14521 — Methods B and C. The author also highlights the new possibilities offered on that basis for the further evolution of load capacity calculation of a worm gearset based on load and contact pressure distribution.
Recently I had a disturbing conversation with a colleague here at the office. During the conversation, it became clear to me that my co-worker -- a really
intelligent guy whom I respect a lot -- had no idea how even the most simple electric motor works.
