In most cases, industrial power transmission calls for flexible rather than rigid couplings in order to forgive minor shaft misalignment. For that reason, this article will focus solely on the selection of flexible couplings.
The availability of high-strength shaft materials, in combination with bearings with high carrying capacity, allows use of slimmer shafts. However, the modulus of elasticity remains the same, so seat
design for bearings and gears must be given close attention.
