The SKF Generalized Bearing Life Model is (GBLM) an innovative new bearing rating life model that is designed to help engineers calculate bearing rating life in a more realistic manner. The new model is a major step forward for the industry and will play an important role in enabling OEMs and end users to better match bearings and applications, resulting in improved machine life and reduced operating costs.
Implementing product lifecycle management strategies can be intimidating at first glance, but it's also necessary. Here's why and how you should implement a PLM strategy of your own.
life in this application.
