A quick search of the patents issued, as well as a review of recent articles, shows a wide range of what authors call “servo stepper motors,” “closed-loop step motors,” “hybrid servo motors” and the like. Although the names may sound similar, the performance can vary quite substantially. Most of the “closed-loop stepper motors” are not actually servo motors!
In the past, we designed motors and drives separately from the mechanical system, and then we integrated suitable components to make a system work. Increasingly, though, the design focuses more on the overall system aspect and system integration, which makes the design of customized components more challenging. In this article, we will use examples of specific software tools, and it should be noted that these are just that: examples. For many of these tools, multiple similar and good software packages exist that can be used.
Prepared by members of the AGMA Flexible Coupling Committee
June 6, 2022
The technical division of AGMA directs the committees that develop and maintain standards and information sheets pertaining to the gear industry. Although often viewed as an accessory for gearboxes, flexible couplings are critical components of any machinery system, since they connect two separate pieces of rotating equipment. The Flexible Coupling Committee is responsible for 12 standards and one information sheet that are specific to flexible couplings. Six of those standards encompassing three subjects will be highlighted in this article.
As well as evaluation of profile, helix and pitch deviations, harmonic analysis of measured 2D trace data is routinely used by some industries to control gear noise and characterize machine tool performance. Evaluation of 3D surface measurement data has not been investigated.
A look at several Two-Phase Hybrid Step Motors and their dominant error sources, and comment on how the errors are overcome by true servo operation of these motors.
Considering the local flank parameters, such as pressure or transmission error, a significant influence of the load-dependent center distance can be observed. With the FVA-Workbench, the load-dependent center distance is always considered.
Linear guide systems are perhaps the most diverse group of products in the motion control industry. Here's how to pick the best one for your application.
