A high force Linear DC servomotor from Moticont has been added to their expanding line of voice coil or moving coil motors. The LVCM-095-038-01 Linear Voice Coil Motor is a true servo motor featuring zero cogging, high accuracy, and high repeatability when operated in a closed positioning loop
The DMC-3x01x Motion Controller Series is Galil's latest generation single-axis motion controller. It uses a 32-bit RISC processor to provide higher speed than older models. Like all Galil controllers, programming the DMC-3x01x is simplified with two-letter, intuitive commands and a full set of software tools for servo tuning and analysis.
Optimal Engineering Systems, Inc. (OES) has released four new high resolution, high repeatability XY Alignment Stages. The AU200-120x120 Alignment Stages feature 120 mm (4.724 in.) of travel in both the X and Y axes. These new low profile 87 mm (3.425 in.) high XY stages, have a 188 mm x 188 mm (7.401 in. x 7.401 in.) open aperture. Easy integration of tooling and fixtures is facilitated through a precision series of threaded mounting holes.
SMAC Moving Coil Actuators recently introduced its new LPL Series 125 low-profile electric linear actuator designed specifically for use on robot end effectors.
The new production plant is officially in operation after its formal unveiling at Lafert’s 60th anniversary celebrations in San Donà di Piave, Italy, close to the historic headquarters.
Jake Schieffer is taking on a new role within Beckhoff USA as vice president of sales. This promotion results from Schieffer’s significant successes as regional director – Midwest. In the newly created national position, he will continue to promote business alignment throughout the sales organization and accelerate growth across the U.S. Based at the Beckhoff USA headquarters office in the Minneapolis area, Schieffer reports to President Kevin Barker. After Schieffer’s promotion, Steve Boelte was selected to fill the position of regional director – Midwest.
