In order to analyze the different gear
oils suitable for the lubrication of wind turbine gearboxes, five fully formulated ISO VG 320 gear oils were selected. In between the selected gear oils, four PAO base oils can be found: PAOR, PAOM, PAOC and PAOX. A mineral-based oil (MINR) was also included as reference.
Third-quarter earnings confirmed
the worst-case scenario — plunging oil prices are whacking almost the entire industrial sector. The theme is hardly new, as the pattern of our headlines has revealed over the past fifteen or so months:
Third-quarter earnings are confirming the worst-case scenario, i.e. — not only are energy related end markets in a downturn, but conditions continue to worsen.
