VCI bags allow auto parts manufacturers and suppliers to eliminate greasy rust preventatives and opt for the dry protection of VCI film instead. Unfortunately, some VCI bags are doomed to failure, leading to the very corrosion that the VCI bag user was trying to prevent. To avoid these negative consequences, Cortec shares the best path to making sure your next VCI bag is the corrosion solution and not the problem.
AutomationDirect has added more ProSense XTH2 series fixed range, head-mounted temperature transmitters to their lineup of temperature transmitters/signal conditioners. The XTH2 series fixed-range transmitters are for Type Pt100 3-wire RTDs and are ready to use out-of-the-box with pre-configured measuring ranges up to 500°F (260°C).
SKF has expanded its portfolio of Condition Monitoring solutions with the SKF Enlight Collect IMx-1-EX sensor solution. Wireless monitoring of assets helps predict machine failure before it can escalate into a serious problem, such as an unscheduled shutdown. This can deliver multiple benefits, including reduced costs and a more sustainable operation of equipment.
Intellidrives Theta 2 theta stage consists of two rotation stages arranged in such a way that axis of rotation for both the stages are same. Both stages have preloaded ball bearing guides for wobble free rotation and positioning. 360° limitless movement is possible for inner and outer stages.
The Ohio State University was joined by Ohio Lt. Gov. Jon Husted, congressional leaders, Honda, Schaeffler Americas and JobsOhio officials recently to announce the creation of a new battery cell research and development center.
Siemens Digital Industries Software recently released HEEDS AI Simulation Predictor software and Simcenter Reduced Order Modeling software. These tools empower engineers to tackle the most complex challenges manufacturers face, delivering predictive performance with speed, precision, and efficiency.
Edilservice from Tuscany (Italy) has joined the Mollo network as of November 1, 2023. It's headquartered in Monteriggioni, Siena, and now becomes the 54th active Mollo center in Italy and the 5th in Tuscany.
Moticont has released the GVCM-022-013-01 Linear Voice Coil Servomotor. This compact .875 in. (22.2 mm) diameter high speed, high force-to-size linear motor features high accuracy and high repeatability when operated in a closed loop as a DC servo motor. This brushless servo motor is clean, quiet and has long life, low mass and high acceleration/deceleration for high throughput.
Forest City Gear is proud to share that Mindy Young, shareholder and third daughter of Fred and Wendy Young, has been invited to join the Rockford Symphony Orchestra Foundation Board. Since 2007, the Board has been dedicated to financing and supporting the mission of the Rockford Symphony Orchestra.
Randy Stott, publisher of Power Transmission Engineering and Gear Technology magazines, recently sat down with Norm Parker, technical fellow and technical manager for Torque Transfer Systems at Stellantis, to discuss bearing technology during the Motion + Power Technology Expo in Detroit.
