The concept is simple enough. Take the traditional rocking chair, the one you’d find on a front porch or the corner of the living room, and give it a 2012 twist.
Even when the critical components of industrial power transmission gear drive systems are properly designed, specified
and manufactured consistent with application requirements, performance
problems can develop over time and failure may follow.
In most cases, industrial power transmission calls for flexible rather than rigid couplings in order to forgive minor shaft misalignment. For that reason, this article will focus solely on the selection of flexible couplings.
Regardless of where you do business, when discussing, analyzing or worrying about “The Economy” these days, you’re
not thinking Main Street - you’re thinking global. With that stipulation, it is also accepted wisdom that quality products and sharp pencils are not enough to be and remain competitive.
Accordingly, everyone is looking for an edge, an advantage, in order to beat back - or at least keep up with - the
competition.
A new solution has been developed around
the use of microprocessor-controlled
prostheses. Just like natural limbs, these
can react automatically, adapting to the
current situation.
This paper provides an overview of the more common position sensor options and references actual case studies to
illustrate the diverse solutions available and the reasons behind some of the decisions. Three cases are used to illustrate the needs of different applications leading to the choice of a particular type of position sensor. The cases reviewed include a gantry crane, wind turbine and aerial cable car.
