AGMA's Gear Expo is now the Motion + Power Technology Expo. Over three action-packed days, end-users can shop the latest technology, gear products, and services, and compare benefits side-by-side. Prominent exhibitors will conduct demos and host information-rich seminars as well as offer-up technical expertise.
Does the definition of specific sliding mean the same between ISO 21771:2007 and AGMA 917-B97? In ISO, specific sliding is the ratio of the sliding speed to the speed of a transverse profile in the direction of the tangent to the profile. In AGMA, specific sliding is ratio of gear tooth sliding velocity to its rolling velocity.
Asymmetric tooth gears and their rating are not described by existing gear design standards. Presented is a rating approach for asymmetric tooth gears by their bending and contact stress levels, in comparison with symmetric tooth gears, whose rating are defined by standards. This approach applies finite element analysis (FEA) for bending stress definition and the Hertzian equation for contact stress definition. It defines equivalency factors for
practical asymmetric tooth gear design and rating. This paper illustrates the rating of asymmetric tooth gears with
numerical examples.
Dale Renner, CBS and sales representative at Bearing Headquarters Co., explains how his bearing expertise
helped solve a customer’s problem
and saved significant downtime and
cost.
