For the fourth consecutive year, AD has been recognized as a Top Workplace in the Delaware Valley. The anonymous employee engagement survey, administered by technology partner Energage, LLC, measures 15 drivers of engaged cultures that are critical to the success of an organization, including alignment, execution and connection. The awards program, in partnership with The Philadelphia Inquirer, recognizes organizations that outperform in a crowded market, lead a people-first culture, and excel at attracting top-tier job seekers and new business.
For a maintenance crew, it is important to know which bearings need re-lubrication and make sure they are lubricating those bearings. The bearings can be lubricated manually or by automatic lubrication systems. This article
will review each method and discover its pros and cons.
Understanding proper bearing lubrication procedures is critical to ensuring long-term, trouble-free performance. Klüber Lubrication has prepared this explanation as a general guide.
Power Transmission Engineering Highlights Latest Bearing Technology
August 1, 2017
