Implementing a power-on-demand concept based on variable speed drives allows for energy saving in any application
that involves pumps or hydraulic systems. And when used in combination with an intelligent wiring and communication system, relevant machine data can also be easily recorded
- the basis for comprehensive power management.
life in this application.
When the need arises for linear motion
or positioning, there are many choices.
One can use an Acme screw, ball screw,
rack & pinion, or belts. The cost of a linear motor solution is generally greater than a mechanical linear product, but when one needs highly accurate, repeatable, high-speed motion, then the answer may be a linear motor.
