More energy efficiency, higher performance and better controllability are the main reasons why more electric drive systems are being operated with frequency converters. However, these devices can cause high-frequency, asymmetrical interference currents, which, as a current passage through the output and fan-side bearings, can cause damage and premature failure.
Current-compensated CoolBlue toroidal cores made of Magnetec’s nanocrystalline material Nanoperm have proven to be effective protection against such conducted interference and its consequences. In addition, the Nanoperm Line Absorbers NaLA can also be used to significantly suppress symmetrical interference currents.
The AD Bearings & Power Transmission community gathered in
Charleston, South Carolina from August 15 to 17 for the group’s annual Network Meeting,
strengthening connections and collaborating for mutual growth.
ABB is set to feature high-efficiency motor solutions during WEFTEC in Chicago, Illinois, USA, on October 2-4. Attendees are invited to visit Booth 2348 to learn from ABB experts about the company’s innovative products and services and the essential solutions they provide for water management and wastewater treatment. ABB’s Global Segment Manager Todd Huston and Global Product Marketing Manager Stefanie Casimir welcome visitors at the booth to discuss these products and their benefits to customers.
This year’s WEFTEC technical exhibition and conference will see Sulzer presenting several innovations in pumping, equipment control, filtration and aeration technology for the water and wastewater sectors. Exhibiting at Booth 3625 in the South Hall of McCormick Place in Chicago, IL., Sulzer’s water experts will be available from October 2-4 to discuss new advancements in energy efficiency, reliability and sustainability.
Nord supports companies in undertaking the use of high efficiency electric motors funded by a program of the Federal Office for Economic Affairs and Export Control (BAFA) and thus taking an important step towards energy efficiency and sustainability. Funding is available for both drives in new plants and conversions to more efficient systems, with up to 40 percent of the investment costs being covered.
