At this year’s AIMEX, Sulzer will demonstrate its extensive knowledge of mining equipment. Offering a comprehensive range of services, Sulzer’s experts deliver cost-effective, pro-active maintenance support for all rotating equipment.
Atlas Energy Solutions has selected Voith Turbo to supply a total of 21 TurboBelt 800 TPXL fill control fluid coupling drives (including spares) to power 42 miles of conveyor belt as part of Atlas Energy Solutions’ historic Dune Express project. ELIN Motoren, a Voith company, will also provide 21 customized low noise electric motors for the project, including spares. Once in operation, the overland conveyor system will serve as a low-impact transport system, taking sand from Texas to New Mexico while establishing a new world record for a single conveyor flight without a mid-belt drive at an impressive 16.3 miles overall single flight length.
NTN Bearing Corporation of America is pleased to announce the release of its latest product offering, the SNC plummer block. The SNC blocks are yet another heavy-duty mounted unit designed specifically to accommodate the rigors of applications within construction, mining, and other large-scale equipment applications.
After nearly five years of planning, Continental is excited to announce Atlas Energy Solutions has contracted Continental to supply the conveyor belt for the Dune Express, a world-renowned conveyor system accompanied by digital solution components.
The Transfluid MPD (multiple pump drive) is an innovative split drive module designed to sandwich between the main diesel engine and transmission. It features an integrated flexible coupling on the input side and an SAE standard flywheel and housing on the output side. Gear driven PTO heads provide multiple pump pads for mounting pumps, while the output flywheel ensures adequate power transfer to drive larger transmissions.
Kollmorgen has announced ATEX certification and IECEx/cETLus listing for the explosion-proof Goldline EBH 480 Vac servomotor. These new explosion-proof approvals for the high-voltage Goldline EBH servomotor exemplify Kollmorgen’s commitment to advancing the state of the art in motion control and meeting the most demanding application requirements.
Salim Haffar, deputy general manager at I-MAK, was reelected as president of EUROTRANS in 2022. This is Haffar’s third term in this role. PTE recently caught up with Haffar to discuss the evolution of EUROTRANS, the focus of the International Drive Conference at Hannover Messe and the current state of I-MAK’s gearbox business in Turkey.
ELIN Motoren and Voith launch the first electric motor with integrated safety coupling for the main drive of tunnel boring machines. Water-cooled asynchronous motors from ELIN Motoren contain either the Voith SafeSet to safeguard the entire drive train or the Voith SmartSet for continuous operation, even with frequent torque peaks. Torque limitation increases the productivity of the TBM, protects the machine components, and avoids costly downtimes.
SKF has extended its Microlog Analyzer family of data collection devices with a new model that offers faster measurement collection and greater diagnostic power.
Liebherr expands the existing product portfolio of open circuit pumps by the nominal size of 550 and as a double pump by the nominal size of 1,100 cc (1,100 cm3). Moreover, the new nominal size of 100 adds to the LH30VO family.
