slow speed operation.
The Baldor Reliance RPM AC Cooling Tower Direct Drive Motor is designed exclusively for the cooling tower industry. This motor combines the technologies of the power-dense, laminated frame RPM AC motor with high performance, permanent magnet salient pole rotor designs.
