In everyday life and in the technical fields we often discover that certain decisions are based on “scientific data” when, in fact, they are often founded on historic conclusions that have not been challenged or re-evaluated in a long time. One such common myth is that for a stable and well-tuned drive you should match the motor’s inertia to the load inertia, which is typically done using a gearbox. Two factors lead to that conclusion: a. there is an optimization formula using the time constant of the motor and the load torque that shows that the best acceleration will be achieved if the reflected load inertia matches the rotor inertia; and b. a PID controller, which was commonly used when electric servos entered the marketplace, tend to perform best and appear to be most stable when the inertia are close or matched.
Kollmorgen has announced ATEX certification and IECEx/cETLus listing for the explosion-proof Goldline EBH 480 Vac servomotor. These new explosion-proof approvals for the high-voltage Goldline EBH servomotor exemplify Kollmorgen’s commitment to advancing the state of the art in motion control and meeting the most demanding application requirements.
Regal Rexnord Corporation has launched a redesigned series of its long-serving, industry-leading Autogard F400 Series torque limiter. This next generation Autogard F400 Series offers significant improvements whilst remaining a drop-in replacement for the legacy 400 Series, matching its predecessor in form, fit and function.
Stock Drive Products/Sterling Instrument (SDP/SI) expands their selection of flexible couplings to include the single disk type couplings (short type), series S50XHSM… and the double disk type couplings (standard length type), series S50XHWM…. The disk type flexible couplings are an economical option while providing greater torque capability and improved performance in a reduced size.
Siemens Digital Industries Software and IBM recently announced they are expanding their long-term partnership by collaborating to develop a combined software solution integrating their respective offerings for systems engineering, service lifecycle management and asset management.
The earliest example of a gear train dates to at least 2,000 B.C. when Chinese engineers built a chariot that used a complex planetary mechanism made of wooden gears to let a dragon head continuously point south when driven around (Ref. 1). In Greece, a surprisingly advanced Antikythera gearbox mechanism, incorporating at least 37 precisely crafted bronze gears, was built years later, between 205–60 B.C. (Ref. 2).
When selecting couplings for precise motion applications there are often questions about the most suitable approach for optimizing both performance and economy.
April 6, 2023
